Short Circut Torque Simulation of Generator Rotor.
    • vinay.dv
      How to Simulate the Short circute Torque Simulation of Generator rotor in Transient module of the Ansys?
      This is experiance by the rotor in mili seconds, how capture this effect?
    • erik.kostson
      Hi
      If you know this torque vs time transient behaviour you can then input that as a force/load in the transient analysis.
      All the best
      Erik
    • vinay.dv
      Hello Erik,
      Kindly find the loading condtion and Result of the same in attachment.
      Kindly suugest me is it looking good or weather I need to modify anything.
    • erik.kostson
      I would just suggest to use one step instead of multiple steps (100 over there are now). In one step you can enter by copy and paste your load data say from excel into the tabular data in mechanical.
      All the best
      Erik
    • vinay.dv
      I tried the same thing first, but only a few rows were pasted. I was not able to paste all the data points in one try.
      How can I paste all the data in a single shot?
    • erik.kostson
      Make sure that the 1st step (only step) end time is larger of course than the copy pasted data – so end time for your only step (step 1) should be at least 250 s.
      As I said this is just the way I would set it up, with one step only, of course multiple steps is ok also (check that the results are as you expect - we can not comment on the results).
    • vinay.dv
      After changing the step end time, we are unable to paste the complete data.
      Kindly reffer the sbapshot of the setting.
Viewing 6 reply threads
  • The topic ‘Short Circut Torque Simulation of Generator Rotor.’ is closed to new replies.
