March 27, 2024 at 9:50 am
Sebastian Albarracin
Subscriber -
March 27, 2024 at 9:55 am
ErKo
Ansys EmployeeÂ
Hi
Membrane needs a pretension to build up bending stiffness – (by default there is none - bending stiffness ),
One can use the inistate command to add some tension (hence bending stiffness) before adding lateral pressure loads.
See this post that answers and shows this:
/forum/forums/topic/membrane-simulation-using-shell181/
/forum/forums/topic/how-to-use-membrane-elements-in-workbench/
All the best
Erik
- The topic ‘Shell with membran option’ is closed to new replies.
