August 29, 2020 at 8:49 am
Autonewbie
SubscriberHi,nI am modeling a contact between shell element (mid surface) and solid element on workbench. I did not turn on the shell thickness effect but I run an contact check to make sure they are in contact.nWhen I want to see the difference between on/ off of the shell thickness effect, it did not converge with the shell thickness effect is on. May I know what is the difference? Thanks!n -
August 29, 2020 at 4:08 pm
JJ_Thompson
SubscriberCan you show some images? It will be easier to diagnose the problem by showing the contact set up and BCs. nWhen you do not use the shell thickness effect, contact is detected at the face of the surface body. If the body you have represented by shells has a thickness of T, with the origin of of the coordinate system (say X-coordinate) along the thickness direction being at the midplane, then with shell thickness effect set to No, contact will be detected at x=0. With shell thickness effect set to yes, contact will be detected at x=-T/2 or +T/2.What was your offset type set to? -
August 30, 2020 at 2:20 am
January 4, 2021 at 9:16 am
Rameez_ul_Haq
SubscriberWhen turning ON the shell thickness effect, should the Pinball radius be such that it is greater than the distance between the thickened faces of each the surface bodies in contact, or still the Pinball radius should be higher than the actual distance between the midplanes of the surface bodies in contact?nAnd if we turn the shell thickness effect OFF, then picking any of the thickened faces of the each surface bodies will have no effect on the contact and analysis, right?nWhat effect does the 'offset type' has?. -
January 6, 2021 at 9:10 am
Rameez_ul_Haq
Subscriber,your opinion on this will be so much appreciated.nPlus, consider the figure below. Each plate is 2 mm thick.n
Why does the geometric gap keep on changing with the change in the pinball radius? What does geometric gap imply? nRight now, the SHELL THICKNESS EFFECT is turned to NO, how would you expect the sticking region to change if it is changed to YES?n
January 12, 2021 at 7:49 pm
Rameez_ul_Haq
Subscriber,a reply on this one will be so much helpful.n -
January 12, 2021 at 8:04 pm
peteroznewman
SubscribernThe Pinball radius should be higher than the actual distance between the midplanes of the surface bodies in contact.n
Viewing 6 reply threads
- The topic ‘Shell Thickness Effect’ is closed to new replies.
1565
1386
1242
