Shell-Solid-Association
    • MollyC
      Hello there,
      I'm working on a projekt using Ansys APDL and writing the code in a .mac file. I have a tower(Shell) and a fondation (Solid) and I'm now thinking about how I can couple the two element types. I used the "CPINTF" command (but I'm not sure if it worked the way I want it to) and I read that you can use contact elements. Does anyone happen to have an example of implementing contact elements in a .mac file?
      Or is there anyone out there who has experience using APDL with a .mac file.
      Thank you in advance
Viewing 0 reply threads
  • The topic ‘Shell-Solid-Association’ is closed to new replies.
