Preprocessing
Preprocessing
Shell Mesh Joint with Bolt Pretension: Contact between the beam & hole
    • snilkar
      Hi Peter.  You had created a video on Apr 28, 2020 about Shell Mesh Joint with Bolt Pretension.  Between time 7:32 and 7:38, you mention about contact between the beam and the hole in another video.  Did you make one or is there another resource that shows how this can be done?
      If others are also aware of this topic, can you please help out in this regard?  Thanks.
      Pat
    • mohan.urs
      Hey,
      This post seems relevent to contact between beam and hole. Do check it out once.
      Contact formulation for beam with bolted joints, using shell elements (ansys.com)
      Thanks
