January 23, 2019 at 9:07 pm
yk2359
SubscriberHello,
Is it possible to apply loads/supports on both inner & outer surface of a cylinder created as a thin membrane with certain thickness? Does shell only allows one face selection(normal vector assigned)? Please advice.
Thanks,
YK
January 24, 2019 at 1:49 am
peteroznewman
SubscriberIf you apply a Pressure load, you simply put a -ve sign on the magnitude if you want the pressure to be on the other side.
If you are defining contact with a surface, you identify if the contact face is the Top or Bottom face of the surface to indicate which side you are defining contact.
January 24, 2019 at 2:04 am
yk2359
SubscriberThanks peter. I have fluid-structure interface on inner and elastic support on outer. Negative value doesn't seem to work. Any thoughts? -
February 9, 2021 at 10:27 am
REZK_A
SubscriberHello yk2359nI'm leaving this comment so if anyone faces the same problem can solve it. nSolution : nYou have to define the prober suface normal using for example spaceclaim Follow this link to do sonhttp://help.spaceclaim.com/2015.0.0/en/Content/Displaying_Normal.htmnif your pressure is pointing to the wrong direction just reverse the normal and everything should be okn
- The topic ‘Shell element face selection or normal assignment’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
1487
1338
1188
