September 12, 2022 at 2:45 am
September 12, 2022 at 3:03 am
Devendra Badgujar
Forum ModeratorHello Roberto
Let me check and get back to you.
Regards.
September 12, 2022 at 3:16 am
Roberto
SubscriberHello Devendra Badgujar
Thank you very much for your help
Regards
September 13, 2022 at 2:40 am
Devendra Badgujar
I was able to reproduce this at my end. I have created a Bug ( 706427Â ) for this issue ad will update you as I get more information on this.
Regards.
September 13, 2022 at 7:54 am
Roberto
The customer will have to make about twenty of these pieces, it is very inconvenient to make the joints one at a time, I hope that the problem will be solved in the next version.
is it possible to make an upgrade? to make sure that the joints are also created between components of equal thickness? it would be very convenientRegards
September 13, 2022 at 11:38 am
Devendra Badgujar
Forum Moderator Roberto
Thanks for your feedback on this. Will let you as I get more information on this.
For your upgrade, I will create an Enhancement request to be added.Â
Regards.
September 14, 2022 at 3:09 am
Roberto
I sent you another file, with another problem
Regards
September 14, 2022 at 3:41 am
Devendra Badgujar
Forum ModeratorRobertoÂ
I checked the file and it looks like you trying to create that from Sheetmetal tab and not Design tab, so it is creating a flange and not plate.Â
Try creating the same from Design Tab.Â
Regards.
October 12, 2022 at 6:09 am
Devendra Badgujar
Bug no (706427) for this issue should be fixed in 2023 R1.Â
Thank you.Â
October 12, 2022 at 6:14 am
Roberto
SubscriberHello Devendra Badgujar thank you very much!
- The topic ‘Sheet Metal Error’ is closed to new replies.
5824
