June 10, 2021 at 9:10 am
Roberto Granito
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsHello I am attaching a video to indicate the error. I have projected an image but on the unfolded sheet metal it is not seen and if I save in dxf / dwg it does not export the lines. I have performed several tests and it is a BUG it is no longer possible to project the geometries on the unfolded sheets as they are not displayed, and if they are exported in dwg dxf they are not displayed. This BUG must be solved as soon as possible. I tested it with previous versions, the BUG is present from 2020R1 onwards  Best Regards -
June 10, 2021 at 10:38 am
Naresh Patre
Ansys Employee -
June 10, 2021 at 10:45 am
Roberto Granito
SubscriberHello Naresh Patre
is it fixed in the new version?
Best Regards
June 10, 2021 at 10:52 am
Naresh Patre
Ansys EmployeeHi Roberto
It has been fixed in 2022 R1 (next year).
August 2, 2021 at 2:09 pm
Roberto Granito
SubscriberNaresh Patre Hello
I update you that in the 2021R2 version the projection works almost completely.
The thing that will need to be corrected is the exposure of the lines projected on the folds that still cannot export correctly.
I attach videoBest Regards
- The topic ‘SHEET METAL BUG’ is closed to new replies.
1565
1386
1242
