December 23, 2021 at 11:22 am
Roberto
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hello, in the version of SpaceClaim 2021R2
when unfolded a sheet with a bend table, the software still develops the sheet even if the internal radius in the bend table is not thereIt should give error is not unfolded the file, it is a serious error!
Regards
December 23, 2021 at 12:47 pm
Subashni Ravichandran
Forum ModeratorHello Roberto
I'm looking into this. I'll get back to you.
January 10, 2022 at 4:39 pm
Roberto
SubscriberHello Subashni
Do you have any news?
Regards
January 19, 2022 at 8:07 am
Roberto
Can you give me some updates?
Regards
January 19, 2022 at 11:59 am
Apologies for the delay. Would you be able to share the bend table you are using?
January 19, 2022 at 1:41 pm
Roberto
Subashni Hello
Here is the file.
all tables do so also the default one (in SpaceClaim) attached.
If it's a BUG can you give me an answer quickly? thank you
Regards.
January 28, 2022 at 12:41 pm
Roberto
Have you tried to run the error with your pc?
Regards
February 7, 2022 at 8:19 am
Roberto
Can you give me some feedback?
Regards
February 16, 2022 at 9:16 am
I'm facing the same issue with this. Let me file a bug for this issue.
February 16, 2022 at 2:56 pm
Roberto
SubscriberSubashni Hello
Thank you for reporting it as a BUG, if it is possible to be able to fix it in the next version that would be great.
As of today, many customers who use bending tables are wrong to create the developments and consequently there is an economic damage since the piece has to be thrown away.Best Regards
May 5, 2022 at 10:30 am
Roberto
Could you give me the BUG number
Regards
October 7, 2022 at 5:51 am
Forum ModeratorRoberto
Upon checking with my team they suggest that the bend table needs to be selected when the bend is made.
In the video shared here, it looks like the bend table is selected later.
October 7, 2022 at 6:02 am
Roberto
this does not solve the problem, it should give me an error saying: in the bend table there is not the following radius value entered.
is should not make the file unfolded.Did you understand the mistake?
The solution you gave me does not solve the problem
Regards
October 11, 2022 at 3:50 am
Roberto
SubscriberSubashni Let me know something
Thank you
June 30, 2023 at 5:33 am
Guillaume ANFOSSI
SubscriberHello,
We have many customers who receive every days files they haven't modeled and that they have to unfold for manufacturing.
To obtain the right unfolded shape, they specify a bending table according to the thickness of the part.
But bending tables require a bending radius to be specified with the associated bend deduction
if the bending radius of the part does not match that of the table, the k factor is used and so the unfolded version is not quite right
A solution is to modify the bend radius of the part, but this not always easy to change, depending on the complexity of the part.
if I understand correctly, the parameter “KFactorFallback
” should avoid the unfolding of a part if the radius of one of the folds does not match those of the folding table? Is this correct ? I have tried to apply it but without success.
Perhaps it would be interesting not to enter a radius in the tables and that whatever the radius modeled, the unfolded is calculated only on the value of the table.
June 30, 2023 at 8:27 am
Roberto
SubscriberHello GUICAD
I am attaching here the link to the answer that was given to me
Regards
- The topic ‘Sheet Metal Bug’ is closed to new replies.
5694
1891
1419
