April 5, 2024 at 8:40 pm
jc47948
SubscriberHello, I've been struggling for days trying to get the deformation to stay put (minus the elastic springback). Can I do this without a whole Multilinear isotropic hardening tabular data input in engineering settings? Or do I have no choice but to do that? I tried that and it solves for many hours then fails.
Any help would be greatly appriciated, as I can't seem to get this to work! (I'm an ANSYS noob)
Start^
Pressed^
Goes back no deformation^
Displacement setting^
April 5, 2024 at 10:45 pm
peteroznewman
SubscriberThe simplest plasticity material model is the Bilinear-Kinematic. All you need to define is a Yield Strength. Use 0 for the Tangent Modulus. This will create an Elastic, Perfectly-Plastic material.
You should remesh the flat plate and put at least 4 elements through the thickness. If you make the elements Linear, you should put 8 elements through the thickness. This will help it stay bent.
You should use a 2D Plane Strain analysis to save on the solution time. You could also save some time by taking advantage of symmetry.
You don't need 21 steps, you can do it with 2 steps, but you will need to increase the number of substeps to 100 Initial, 100 Minimum and 1000 Maximum.
April 5, 2024 at 11:22 pm
jc47948
SubscriberPeter, thank you so much for your help!!! I'm really starting to dig ANSYS mechanical, but have a lot to learn obviously. This is the second time you've helped me out and it is much appriciated.
- The topic ‘Sheet Metal Bending – No Plastic Deformation’ is closed to new replies.
5694
1891
1419
