Shear Test – Mooney Rivlin
    • Harry Begy
      Hello. I cannot fix this issue ! I have changes the substeps, "adjust to touch", Automatic time stepping, rigid body motion etc. Please assist me. Thanks a lot.
      Th error is as follows;
      Elastomer Sample (Mooney Rivlin) contains invalid property data. Elasticity is required, but is currently undefined.
    • Akshay Maniyar
      Hi Hary,
      As per the error message, it looks like you have some issues with the material you are using. The elastomer sample material that you have used has only test data which is needed to create the hyperelastic material model. Go to Engineering data and create the proper material model. Please ensure that you have all the material properties defined as per the analysis you are performing.
      How to Perform Curve-fitting for Hyperelastic Material Models — Lesson 1 - ANSYS Innovation Courses
      Thanks,
      Akshay Maniyar
  • The topic ‘Shear Test – Mooney Rivlin’ is closed to new replies.
