October 9, 2019 at 7:24 pm
Prashank
SubscriberI am trying to simulate the 3 point bending test of sandwich composite. For this i replaced the honeycomb core geometry by solid core after giving the same orthotropic properties to the solid core.(homogenized)
The bending stress in the face sheet and the central deflection of the sandwich matches the analytical result.
 The value of shear stress in the honeycomb core by analytical method is 0.369 Mpa. While the shear stress in the solid core is about 0.471 Mpa.
My questions are:
1. This method holds good for the deflection and bending stress in the face sheet but can i expect the similar accuracy in the stresses in solid core.
2.The below research paper suggests the relation between the shear stresses in the solid core geometry to the honeycomb geometry. But when i put the values to check it , the difference between the analytical and FEA values increases by a great margin.
LITERATUREÂ
ANALYTICAL METHOD TO FIND OUT SHEAR STRESS IN HONEYCOMB CORE:-
shear stress in xz plane = P/(D+C)xB
Where P is the load = 400Â Â
C is core height = 12.7 mm
Dis sandwich height=13.1 mm
b is sandwich width=42 mm
so value comes out to be = 0.369 MPa
ANSYS:-
Shear stress in the xz plane is 0.471 Mpa
LITERATURE 2
Another research paper established a relationship between the shear stresses in the actual honeycomb core and homogenized solid core.
b = 5.499mm , t =0.2 mmÂ
so as per the first relationÂ
shear stress in the honeycomb core = (b/t)x shear stress in XZ plane of solid core.
b/t = 27.496
But
shear stress in honeycomb core =0.369Mpa
shear stress in homoginesed core ( by ansys) =0.471 Mpa
so the above relation is not satisfied.
here is the research paper.
October 16, 2019 at 4:52 am
Sandeep Medikonda
Ansys EmployeeLooks like the FEA analysis in the above paper were also performed in ANSYS (classic). You might be able to get a better answer by reaching out to the authors directly....
- The topic ‘shear stresses in the homogenized core of sandwich panel’ is closed to new replies.
4708
1565
1386
1242
