September 1, 2025 at 2:44 am
powerrep3
SubscriberHello, I'm trying to compare the analytical result with the simulation result for the shear stress of a bolt.ÂThe bolt has a diameter of 16 mm. It is located at the center between two sliding plates. One end of the top plate (left side) is subjected to a 15 kN force, while the opposite end of the bottom plate (right side) is also subjected to a 15 kN force. The calculated analytical result for shear stress is 74.6 MPa.ÂI ran the simulation in Ansys. The contacts were set to frictionless for the sliding parts only and bonded for the other parts. The results I obtained with different mesh sizes are:Â20 mm mesh size → 50 MPaÂ10 mm mesh size → 60 MPaÂ5 mm mesh size → 66 MPaÂ2.5 mm mesh size → 74.8 MPaÂ1.25 mm mesh size → 119 MPaÂI thought I was on the right track since the 2.5 mm mesh gave a result very close to the analytical value. However, I expected the 1.25 mm mesh to give an even closer result t0 74MPA , but instead, it gave a much higher stress.ÂIs there something wrong with my setup? Thanks -
September 1, 2025 at 4:42 pm
peteroznewman
SubscriberHow is this structure connected to ground? A better set of loads and supports would be a fixed support on the bottom plate face where the force is applied, and that force deleted. The reaction force of the fixed support will be 15 kN in the normal direction.
Are the bonded faces only the annular ring of the nut and bolt head to the bottom and top faces of the plates?
Is there frictionless contact between the shaft and the two holes?
Ansys Innovation Space
1394
1188
1100
1015
