February 4, 2021 at 2:54 pm
YannickScholz
SubscriberHey Guys,nI?m new here and I have a problem. I want to calculate the shear stress of the fluid in a pipe and not on the wall. How can I do this. nThanks, if you have any ideas or answers.n -
February 4, 2021 at 3:53 pm
Amine Ben Hadj Ali
Ansys EmployeeFluent provides you the velocity gradients as well as the strain rate you can code it on your ownn -
February 5, 2021 at 1:46 pm
YannickScholz
SubscriberHi DrAmine,nthanks for your answer. How can I code it on my own?n -
February 5, 2021 at 3:37 pm
Forum ModeratorIt's a function of strain rate, velocity gradients and viscosity so use a Custom Field Function or UDF and dump the value to a User Memory. n
- The topic ‘Shear Stress in Fluid’ is closed to new replies.
- affinity not set
1487
1318
1156
