April 9, 2020 at 3:39 pm
April 9, 2020 at 5:02 pm
peteroznewman
SubscriberConvergence will be easier to achieve if you put a small radius on the tips and equally small elements facing the tips. Start with a 2D Plane Strain model to have it run faster. Use two planes of symmetry and model only 1/3 of the circle to make it run even faster. Those suggestions are only useful if the loading is symmetric.
April 12, 2020 at 1:59 pm
Autonewbie
SubscriberIf I would like to find out how much is required to remove the inner part, is frictional stress at the contact tool the right stress to look for?
April 12, 2020 at 5:14 pm
peteroznewman
SubscriberI don't understand the question. Describe what you want to know in more detail. Between the triangle and ring, which part is stiff and which part is soft/flexible?
April 13, 2020 at 1:34 am
Autonewbie
SubscriberI missed out some words. I was trying to find out the required force to pull out the inner part from press fit but I found the right output now.Â
However, customer told me that the inner part is come with sharp corner no corner radius...
- The topic ‘Sharp Contact Point’ is closed to new replies.
2773
965
841
599
591
