September 16, 2022 at 7:26 pm
nzimronpoliti
SubscriberHi,
Need help with setting up a parametric modal analysis in WB. It's a simple run that repeats with a varying parameter.
I have ansys workbench installed on linux HPC an would like to run using parallel computing.
How do I set this up with shared memory mode?
Thanks.
September 17, 2022 at 2:10 am
peteroznewman
SubscriberIn Workbench, to use shared memory mode, simply uncheck the Distributed Ansys checkbox on the Solution Parameter Settings.
September 17, 2022 at 3:58 pm
peteroznewman
SubscriberIn my benchmark testing of 10 different models, the solution took less time when Distributed was checked than when it was unchecked. Why do you want to uncheck it?
September 21, 2022 at 7:28 pm
nzimronpoliti
SubscriberThank you!
Un-check the box worked.
The reason I'm using shared memory is my group's policy.
September 21, 2022 at 10:59 pm
peteroznewman
SubscriberOh! A policy that slows things down for ANSYS users. What is the benefit of such a policy? You don’t have to answer that.
What I would do is run a few benchmark tests to show what that policy does to the ANSYS solution time, then I would have data to argue an exception to the policy for ANSYS users.
- The topic ‘Shared memory mode in workbench’ is closed to new replies.
6144
