December 2, 2020 at 7:09 pm
zyao1
SubscriberDear everyone,nnI have an issue when using the Ansys FLUENT Optimizer.nnThe case is a tunnel, with the water flowing through it.nThe top surface is the wall, the bottom surface is wall with heat flux.nThe two side surfaces are symmetry.nThe objective function is minimizing the temperature of the bottom surface.nI already made a case with smaller thickness proving the bottom surface temperature is smaller, showing in the picture below.n
But when I try to optimize the same case, there is negligible change for the geometry and the thickness does not change. (for the optimization, I set the constraint that the geometry could only change in y direction, which is the thickness direction)n
I also made vector plots of sensitivity of optimal displacement for this energy case (objective function is minimizing temperature) and case without energy(objective function is maximizing the pressure drop between inlet and outlet),nFrom the plots, the geometry can not change in y direction (thickness direction) with energy on, but for no energy case, the design will be changed in y direction. These plots are also shown in the picture below.n
My question is why the optimizer does not make the geometry of energy on case change in y direction(thickness direction) and can make the geometry of energy off case change in y direction(thickness direction)?.Thank you for any reply!nnzyaon
December 3, 2020 at 11:13 am
Keyur Kanade
Ansys EmployeeDuplicate of nDear everyone,I have an issue when using the Ansys FLUENT Optimizer.The case is a tunnel, with the water flowing through it.The top surface is the wall, the bottom surface is wall with heat flux.The two side surfaces are symmetry.The objective function is minimizing the temperature of the bottom surface.I already made a case with smaller thickness proving the bottom surface temperature is smaller, showing in the picture below.https://us.v-cdn.net/6032193/uploads/A3832RP88RRT/shape-optimization-issue-1-png.pngBut when I try to optimize the same case, there is negligible change for the geometry and the thickness does not change. (for the optimization, I set the constraint that the geometry could only change in y direction, which is the thickness direction)https://us.v-cdn.net/6032193/uploads/9FOBNBO1X53A/shape-optimization-issue-2-png.pngI also made vector plots of sensitivity of optimal displacement for this energy case (objective function is minimizing temperature) and case without energy(objective function is maximizing the pressure drop between inlet and outlet),From the plots, the geometry can not change in y direction (thickness direction) with energy on, but for no energy case, the design will be changed in y direction. These plots are also shown in the picture below.https://us.v-cdn.net/6032193/uploads/TQ9TKKGCUVBJ/shape-optimization-issue-3-png.pngMy question is why the optimizer does not make the geometry of energy on case change in y direction(thickness direction) and can make the geometry of energy off case change in y direction(thickness direction)?Thank you for any reply!zyao/forum/discussion/22544/shape-optimizing-the-tunnel-case-with-energy-on-in-fluent
n
- The topic ‘Shape optimizing the tunnel case with energy on in FLUENT’ is closed to new replies.
- affinity not set
- Continuing SAG Mill Simulation with New Particle Batch in Rocky
4512
1494
1386
1209
