March 19, 2023 at 10:01 pm
Christof Schramm
SubscriberHello,
Please take a look and the attached PDF. When I form a rectangle in the sketch mode, I often use direct inputs of dimensions. Since the upgrade on R3 the rectangle jumped to a wrong position when I hit the "Enter" key after putting in the last dimension.
Is this a software problem?
Best Regards,
Christof Schramm
March 20, 2023 at 2:47 am
Subashni Ravichandran
Forum ModeratorHello Christof Schramm
I've not see this issue before.
It may have something to do with the model you are working on.Can you please share the model so that I can check at my end?
March 20, 2023 at 5:02 am
Christof Schramm
SubscriberHello,
pleas find attached the model.
March 21, 2023 at 7:41 am
Christof Schramm
SubscriberHello,
I have installed the patch, but the problem still exists further on. Sorry.
Best regards,
Christof Schramm
March 26, 2023 at 6:55 am
I'm able to replicate this behavior. This seems to be specific to this file. I will be filing a bug for this.Â
In the meantime, as a workaround, can you create the geometry and then use to move tool to drag it into its correct position?
April 14, 2023 at 1:07 am
Forum Moderator817382 BUG ID
April 14, 2023 at 2:58 am
Christof Schramm
SubscriberHello Subashni,
I will try it tomorrow, OK?
Best regards,
Christof
April 14, 2023 at 3:06 am
Christof Schramm
SubscriberI have noticed, that spaceclaim behaves sometime a little weared after importing some files (STEP, IGES, OBJ). The most problems I have watched where with the 2D-sketch tool for example in placing parallel lines to some curves and when I worked with eliptic elements.
- The topic ‘Shape Jumping (Spaceclaim R3 2023)’ is closed to new replies.
4934
1638
1386
1242
