September 25, 2020 at 1:00 pm
soloviev
SubscriberHello,nnWe are looking to load velocity/temperature profiles into a model as boundary conditions at the inlet. Can this be done in a variable manner without manually stopping the model and re-importing profiles and re-starting the model? We are hoping for a way for Fluent to re-read a new profile every either 1 or 10 or time steps.Thanks,nAlexn -
September 28, 2020 at 11:13 pm
Surya Deb
Ansys EmployeeHello, nIs the model transient and you are trying to load a transient profile?nIt is not very clear when you say re-starting the model.nWhy do you need to restart the model? Is it because you want to use the solution from one case to the other with different profile files?nCan you please elaborate?nRegards,nSuryan -
October 15, 2020 at 5:31 pm
soloviev
SubscriberYes. I have looked into this further and found that you can add transient profile files. I am doing this now by loading a csv with a column for 'time'. Does this work in the sense that Fluent will read the time and update the boundary condition variables at the given time using this transient profile file?.Thanks,nAlexn -
October 15, 2020 at 8:27 pm
October 15, 2020 at 9:16 pm
Karthik Remella
Administrator,nHere is an example of the profile file format. Please refer to the following link.nThank you.nKarthikn -
October 16, 2020 at 2:52 pm
soloviev
SubscriberThank you. I see the following example: n
nnHow can I do the top and bottom combined? In my file I am trying to update the transient x,y,z velocity profiles are varying time steps and at x,y,z coordinates, like the top, but at an interval of 1s, 540s, and 1140s. I posted my file above. Should I name the name transient-inlet or transient-velocity instead? But can I combine the xyzzy points and velocities with the time column?.Thanks,nAlexn
October 16, 2020 at 3:24 pm
Amine Ben Hadj Ali
Ansys Employeein Fluent you can consider transient AND spatial profiles at the same time: either you provide a transient input (like velocity magnitude varying over time) or spatial( velocity input varying over X,Y,Z). To have 4 dimensions you require UDF (not even easy to do..).nnI think there will be a way to do that in the feature.n -
October 16, 2020 at 4:59 pm
soloviev
SubscriberThank you. So the best way for now to do this is run the simulation, then start a case with the results from the first run, and add the new profile then continue running? -
October 16, 2020 at 5:36 pm
Amine Ben Hadj Ali
Ansys EmployeeYou can rely on Automatic Case Modifications Feature in Fluent: You read at the beginning all profiles, you prepare the journals to apply the right profile and then execture the modification at the moment you require.n -
October 16, 2020 at 8:33 pm
soloviev
SubscriberThank you! Is this in the user's guide? n -
October 19, 2020 at 11:13 am
Forum ModeratorSort of, the case modifications part is, but the commands you need (TUI) won't be other than at a very basic level in the TUI manual. n -
October 19, 2020 at 4:54 pm
soloviev
SubscriberSo I have looked into this a bit more (online tutorials and user's guide). Will I just use the journal to get my TUI commands to use in the automatic case modification? Or do I need to use the automatic case modification to execute reading journal files?.Thanks,nAlexn -
October 19, 2020 at 8:06 pm
soloviev
SubscriberI worked on this today and found that when I write a journal that reads the profile and sets it in the boundary conditions tab, I can read it into the case fine. When I set it as a case modification, it gives me the attached error. I've also provided the commands I have set to execute in case that's helpful. It does seem to be reading the file at the specified step from the case modification, but I'm not sure why there's an error with the journal when reading that way, but not when I use the GUI to read it.Thanks,nAlexn
n
October 20, 2020 at 11:27 am
Forum ModeratorIf the profile is already loaded you should just need to set the boundary condition. Also /file/read will probably try and read a case as Fluent usually picks the first option in the list if it's not fully defined. n -
October 20, 2020 at 1:10 pm
soloviev
SubscriberSo I should load all profiles at the beginning? I am setting x-velocity, y-velocity, and z-velocity as Cartesian components with each modification. Will it be able to do this in one command? My journal file listed it as ~10 lines of commands.Thanks,nAlexn -
October 20, 2020 at 1:12 pm
soloviev
SubscriberI also just found that it seems the proper TUI command would be file/read-journal. Thanks for pointing out that issue. n -
October 20, 2020 at 1:18 pm
soloviev
SubscriberActually, as an update, changing the auto modification command to read-journal got rid of the error! Thanks!n
Viewing 16 reply threads
- The topic ‘Setting variable inlet profile in model’ is closed to new replies.
- affinity not set
1487
1338
1172
