June 6, 2025 at 5:08 pm
alidhibiani
SubscriberI was training with Forte Academic version and scaled down inside Forte by 40% tutorial chapter 5 port fuel injection but valve error movement failed. Originally tutorial valve set up as shown below, was this angle setup main cause for error? i ttried picking coordinates on middle of valve face but no result.
Accept the default Global Origin for the Reference Frame. Select Spherical for the Coord. System under Direction for the valve motion and set
 =199 degrees and
 =0.0 degrees.
Viewing 0 reply threads
Ansys Innovation Space
1025
962
859
798
