February 17, 2023 at 9:45 pm
Robert Jones
SubscriberHello,
running: Ansys Academic Multiphysics Campus Solution (10/100) -
I am looking for documentation for my IT support who runs our license server. I was told by in a phone call with the vendor we get our software from that you can set up groups through the license server.
EG. Reasearch group, (list users) they would then have access to the 10 acadmics seats that we have. It was mentioned we could setup a way that would limit each user to the number of cores they could use at one time.
For the class room, it was stated we did not need a group as any license default user would be running the classroom portion.
Also is there a way to have my IT tech access the protal as well?
Thanks,
 R. Jones
February 21, 2023 at 3:19 pm
George Karnos
Ansys EmployeeCheck the Flexnet Administrators Guide.
Look for: Options file.
This will allow you to implement licensing rescrictions.
But I do not believe you can restrict the number of cores per run unless you are using
the "anshpc" license.-
February 22, 2023 at 3:34 pm
Robert Jones
SubscriberWhere is the  Flexnet Administrators Guide found, I don't see it under the licensing installtion section.
February 22, 2023 at 4:09 pm
George Karnos
Ansys EmployeeThe PDF is located under the following directory on the License server machine:
On Windows, the Flexnet Admin guide is located:
C:\Program Files\ANSYS Inc\Shared Files\Licensing\licadmin\docu\fnp_LicAdmin.pdf
On Linux:
/ansys_inc/shared_files/licensing/licadmin/docu/fnp_LicAdmin.pdf
- The topic ‘Setting Up user groups to access academic seats through the flex server’ is closed to new replies.
