May 16, 2023 at 7:54 pm
helen.durand
SubscriberHello!
Consider: Denlinger, Erik R., Jarred C. Heigel, and Panagiotis Michaleris. "Residual stress and distortion modeling of electron beam direct manufacturing Ti-6Al-4V." Proceedings of the Institution of Mechanical Engineers, Part B: Journal of Engineering Manufacture 229.10 (2015): 1803-1813.
In this work, the authors are performing a 3D thermal and mechanical analyses of an additive manufacturing process using one-way coupled transient thermal and quasi-static structural analyses.Â
The authors state that: "The thermo-elasto-plastic model presented accounts for the observed stress relaxation by resetting both stress and plastic strain to 0 when the temperature exceeds a prescribed stress relaxation temperature."
I was wondering how this might be accomplished. How would I set stress and plastic strain to zero when the temperature exceeds a value?Â
I am implementing my simulation in transient thermal and transient structural utilizing APDL command blocks. Is there an APDL command that can set stresses and plastic strains to zero? I already have code that is capable of finding the temperature of each element by looking at the nodal temperatures.Â
Thank you!
May 18, 2023 at 8:27 am
Ashish Khemka
Forum ModeratorHi Helen,
Try the following commands for the material input. The commands below define a multilinear isotropic hardening model where for temperature of 66 degree C, the plastic strain is zero and stress is 1e-6MPa. Other data is for 22 and 44 degree C.
TB,PLAS,1,3,3,MISO
TBTEMP,22
TBPT,,0,100
TBPT,,0.1,200
TBPT,,0.2,300
TBTEMP,44
TBPT,,0,100
TBPT,,0.1,200
TBPT,,0.2,300
TBTEMP,66
TBPT,,0,1e-06Regards,
Ashish Khemka
September 7, 2023 at 8:46 pm
helen.durand
SubscriberThank you for the reply!Â
For the 66 °C data, you have only listed a value of true stress of 1e-6 for a plastic strain of 0. Does this mean that ANSYS will continue to use a true stress value of 1e-6 for larger plastic strain values at 66 °C?
Could you explain how this corresponds to resetting both stress and plastic strain?
How does this ensure a plastic strain of 0? It seems like the plastic strain could still be a larger number at 66 °C, and doing what you suggested will just ensure that the stress remains low at 1e-6.
- The topic ‘Setting plastic strain and stress to zero above a stress relaxation temperature’ is closed to new replies.
5819
