February 22, 2022 at 10:27 pmfrancescocurzioSubscriberFebruary 23, 2022 at 3:55 pmfrancescocurzioSubscriberHi Sir, thank you for the interest, but unfortunately this link cant help me! I'm searching informations about the comman OffSet in the menu ElementTool.
March 7, 2022 at 2:17 pmMarch 7, 2022 at 4:37 pmfrancescocurzioSubscriberHi Sir! Thank you for the suggest, but i have found a solution using the offset command and some adjustments! Ill try the way you suggested!
Viewing 3 reply threads- The topic ‘SetOff Command’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- ICEM CFD – Hexa mesh of a tapered wing with sharp trailing edge
- No mesh information was found in the input mesh file error
- Varying ply angle in ACP
- CONVERTING STL FILE IN TO SOLID
- Element type definition – Ansys Workbench
- the matrix T in the cyclic symmetric formula!!
- Assiging one parameter as thinkness of few shell objects
- ANSYS ACP Modelling Issue
- The meshing algorithm cannot find matching topology
- Connecting External Mesh and Beam Model in Ansys Workbench
Top Contributors-
1341
594
591
530
366
