Set up a wall that is permeable to fluid and not to particle
    • admin
      How to set up a wall that is permeable to fluid and not to particle?
    • admin
      Set a porous-jump with the following properties: Face permeability = 10e10 m² Porous Medium Thickness = 0 Pressure-Jump coefficient = 0 Still in the Porous Jump panel, set the Discrete Phase BC Type to reflect
  • The topic ‘Set up a wall that is permeable to fluid and not to particle’ is closed to new replies.
