September 27, 2017 at 11:19 am
admin
Ansys EmployeeYou can set a CEL expression for the heat source such as: HeatIn = HCoef * (Treq - T) where Treq is the required temperature and HCoef is a positive valued power density coefficient (units = [W m^-3 K^-1]). The size of HCoef determines how fast your heat source reacts to temperature changes. You want HCoef to be large enough to give you the behaviour you want but not so large that it makes the solver struggle. Setting the source coefficient to be -HCoef should help significantly with convergence.
admin
Ansys EmployeeHow to set up a heat source in CFX in a subdomain that results in a constant temperature
- The topic ‘Set up a heat source in CFX in a subdomain that results in a constant temperature’ is closed to new replies.
