September 27, 2022 at 1:21 pm
2212296
SubscriberHi guys,ÂThe aluminum is set as a lossy metal witha conductivity of σ = 3.56e+7 S/m,Âhow to set it?Âbest -
September 27, 2022 at 5:49 pm
Guilin Sun
Ansys EmployeeI think you have set it before as you reported huge memory, and this is why I suggest you to use PEC instead. Please refer this post: /forum/forums/topic/about-micron-or-millimeter-wave-simulation/
September 28, 2022 at 12:03 am
2212296
SubscriberYes, I also set the PEC as you said, but the simulation results obtained are different from those in the article
September 28, 2022 at 7:26 pm
Guilin Sun
Ansys EmployeeThen you may need to switchback to conductive material, with a poweful coputer as it requires huge memory. Please do not use override mesh to reduce the memory requirement.
September 29, 2022 at 3:07 am
2212296
Subscriberokay, thank youÂ
- The topic ‘Set the metallic aluminum material properties’ is closed to new replies.
