March 28, 2024 at 11:04 am
Santtu Siponen
SubscriberI'm trying to set the XComponent value of Remote Displacement with scripting. I think the problem is on the last line and has something to do with the fact that it is originally set as 'Free'. Appreciate any help to fix my code!
Code Below,
model=ExtAPI.DataModel.Project.Modelstatic_structural = model.Analyses[0]eigenvalue_buckling = model.Analyses[1]solution=eigenvalue_buckling.SolutionÂx=1ÂÂrd=static_structural.AddRemoteDisplacement()rd.Location=ExtAPI.DataModel.GetObjectsByName("ylaosa")[0]Ârd.XComponent.ToStringÂrd.XComponent.Output.SetDiscreteValue(0, Quantity(x, "m"))Â
March 28, 2024 at 11:07 am
Santtu Siponen
SubscriberLink to appropriate reference guide, https://storage.ansys.com/act/v190/ACTReferenceHTML/Mechanical/index.html#Reference.methode.Ansys.ACT.Mechanical.Fields.Variable.SetDiscreteValue.html
March 28, 2024 at 12:54 pm
ErKo
Ansys EmployeeÂ
Hi
You need this (see link) to make it work. Also as it is a ramped load time=0 can not have a displacement so start at next time point (see below).
Thank you
Erik
- The topic ‘Set Remote Displacement with scripting’ is closed to new replies.
