February 28, 2019 at 11:34 pm
marcocesari
SubscriberHello to everyone
I'm try to specify the license server machine on my laptop by Client ANSLIC_ADMIN Utility. After clicking on ''specify the license server machine'' i add server machine specification and enter the server ip address but when i click on ''view statut display the license status'' gives me the following message:
License server status: 1055@*****
License file(s) on *******: 1055@*******:
lmgrd is not running: License server machine is down or not responding. (-96,7:11001 "WinSock: Host not found (HOST_NOT_FOUND)")
Ansys works perfectly on the server machine and there are also license aviable but i can't use them on my laptot.
Thanks
February 28, 2019 at 11:37 pm
Divya Shree Surendran
Ansys EmployeeHi,
Could you please check if there is a Firewall enabled on the license server that might be blocking the communication from your client machine?
If so, please try to add Firewall exceptions to these exes under C:Program FilesANSYS IncShared FilesLicensingwinx64
ansysli_server, ansysli_monitor, ansyslmd, lmgrd
Thank you.
March 2, 2019 at 3:23 pm
marcocesari
SubscriberI tried to add Firewall exceptions but the problem wasn't solved. Thanks for you help , any other idea ?
Thanks
March 4, 2019 at 4:02 pm
JakeC
Ansys EmployeeHi Marcocesari,
On your laptop, please open a command prompt:
Start -> type cmd -> Click on Command Prompt
then try to ping the license server hostname:
ping server_host_name
Does that resolve properly?
If so, try the same thing from the license server it self (pinging itself).
Do the ip addresses match?
Thank you,
Jake
March 6, 2019 at 7:26 am
marcocesari
SubscriberHi Jake Callery ,
Thanks for your help , I fix the problem .
In the license file there wasn't the right ip address of server machine , so my laptop could not received the license. After changed the ip address on the license file the problem was fixed.
Thanks a lot .
Marco
March 8, 2019 at 1:24 pm
JakeC
Ansys EmployeeHi Marco,
That is great news! Could you please mark this thread as solved?
Thank you,
Jake
- The topic ‘set license server’ is closed to new replies.
3862
1414
1220
1118
1015
