February 11, 2021 at 6:12 pm
ansysuser
SubscriberHello,
I wish to be able to specify the view in CFD post. I get the following error on some code that seems to have worked for some people:
February 12, 2021 at 5:17 pmansysuser
SubscriberAny input?nFebruary 15, 2021 at 4:45 pmSurya Deb
Ansys EmployeeHello, nThe best way to do this would be to record a session file while you move your model in the 3D Viewer. nThen you can open the recorded .cse (session ) file and modify the camera angles. nOnce you do that, you could then read back that session file and will see the necessary changes.nFor example, something like below should work.nCOMMAND FILE:n CFX Post Version = 19.2nENDnnVIEW:View 1n Camera Mode = User Specifiedn CAMERA:n Option = Pivot Point and Rotationn Pivot Point = 0, 0, 0n Rotation = -90, 0, 0n ENDnnENDnn> updatennYou should try recording and then changing at your end.nI hope this helps.nRegards,nSuryannViewing 2 reply threads- The topic ‘Set camera angle in cfd post’ is closed to new replies.
4934
1638
1386
1242
