May 8, 2024 at 3:01 pm
Roberto
SubscriberHello
Many are installing the latest service pack, they are stuck with the work, it doesn't work and this error comes out!
This mistake has already been made once, please fix it! Otherwise you always have to go and change the license from
C:\Program Files\ANSYS Inc\v241\Discovery LicenseModeGUI.exe -
May 9, 2024 at 6:39 am
Charudatta Bandgar
SubscriberLet me check the issues with SP3, Roberto. I will get back to you with more information.
Charudatta B
May 9, 2024 at 6:50 am
Roberto
SubscriberHelloÂ
If possible I would like to know what has been added or what has been corrected.
Best regards
May 9, 2024 at 9:14 am
Roberto
SubscriberHello Charudatta
I would also like to point out another error, after updating the patch it is no longer possible to open scdoc files with a double click, even by setting the application as default.
I have to solve this problem by changing the registry file, this happens often, this problem must be solved for the next versions, the user must not perform these operations often.Regards
May 9, 2024 at 9:40 am
Charudatta Bandgar
SubscriberThanks for informing Roberto, I will convey it over as well.
May 9, 2024 at 9:58 am
Roberto
If it helps you, to resolve the problem I went to Computer\HKEY_CLASSES_ROOT\Ansys 2024 R1 .scdoc File and changed the key by inserting this "C:\Program Files\ANSYS Inc\v241\scdm\SpaceClaim.exe" "%1 " "UseLicenseMode=true"
Regards
May 20, 2024 at 7:40 am
Roberto
SubscriberHello CharudattaÂ
10 days have passed and I haven't received any news, are you solving the problem?
regards
May 24, 2024 at 5:05 am
Charudatta Bandgar
SubscriberHey Roberto,
There does seem to be some issue with SP3, that we are looking into internally. Either way, there isn't any update for SP3 for Discovery, it will have some smaller fixes for legacy products (SpaceClaim, etc.). If it is feasible, while we figure out the issues with SP3, I would suggest you stick with SP2.
Charudatta B
May 24, 2024 at 7:02 am
Roberto
SubscriberHello
Ok fine, the important thing is that in the next R2 version they are correct.
On the web page where you download the software version I would report these BUGS at least the users know how to start the license or other errorsÂ
- The topic ‘Service pack 3 does not work’ is closed to new replies.
5649
1885
1404
1303
