LS Dyna
LS Dyna
self-piercing riveting;SPG;Dynain
    • Jiazhi Zhang
      I want to reappear this result,but,the dyna always report an error when the second stage starts run
      Microsoft PowerPoint - SPG_TwoStage3.pptx (lstc-cmmg.org)
      Error 30073 (INI+73)
           negative or zero determinant - solid element 199545
             node 232133 ( 9.0727E+01, -2.3665E+00, 2.2197E+01)
             node 232283 ( 9.0820E+01, -2.4507E+00, 2.2286E+01)
             node 232433 ( 9.1423E+01, -2.7085E+00, 2.3203E+01)
             node 232273 ( 9.0498E+01, -2.5959E+00, 2.2622E+01)
             node 232134 ( 9.0672E+01, -2.4419E+00, 2.2305E+01)
             node 232284 ( 9.1035E+01, -2.5544E+00, 2.2411E+01)
             node 232434 ( 9.1407E+01, -2.7099E+00, 2.3277E+01)
             node 232274 ( 9.0900E+01, -2.7359E+00, 2.3400E+01)
       Error 30025 (INI+25)
           massless node 227400 on the surfa side of surface 2 type 7
           This could be lead to a segment with no parent element defined.
    • Reno Genest
      Hello Jiazhi,
      Are you using the latest LS-DYNA solver R14.1? Please make sure to use the latest solver. There have been many improvements to SPG and dynain in the last few releases. You can download R14.1 here:
      SMP:
      https://user:computer@ftp.lstc.com/user/ls-dyna/R14.1.0/
      MPP:
      https://user:computer@ftp.lstc.com/user/mpp-dyna/R14.1.0/
      Note that LS-DYNA R15 should be released soon.
      Also, are you rebuilding the model yourself or are you using the model provided by the CMMG group?
      https://www.lstc-cmmg.org/spr
      Let me know how it goes.
      Reno.
      • Jiazhi Zhang
        Sir,I’m excited to tell you it works, but it need too much times, If I change the mass shrinkage,it reappear error.Could you please see if this is normal
    • Jiazhi Zhang
      • Jiazhi Zhang
        Thank you for your reply, Sir.I have already used the model from CMMG group and the latest LS-DYNA solver R14.1. I get the correct dynain and 1234spg. but when I want to finish Shear experiment simulation,it always shows error.
  • The topic ‘self-piercing riveting;SPG;Dynain’ is closed to new replies.
