January 2, 2023 at 7:27 am
January 2, 2023 at 10:19 am
Atharv Joshi
Forum ModeratorHi Benjamin P. ,
Let me check this and will get back to you.
January 3, 2023 at 12:33 am
Atharv Joshi
I tried to recreate your problem and found that "image 2" is expected behavior, if you are changing the count to 1 as shown in "image 3". It will keep the original component only. As you are using move to create pattern this is the expected behavior.
You can try using linear pattern and other pattern feature options available from Design>>Create. Let me know if you need further assistance.
Thanks and Regards
January 3, 2023 at 4:21 am
benjamin.pilon
SubscriberHi Atharv Joshi , many thanks for your reply.
I have found the linear reptition function in the design>create tab but the unfortunately the result is the same.
Best regards, Benjamin
January 3, 2023 at 10:03 am
Atharv Joshi
Can you please provide more information on what exact issue is or a video about it?
Thanks and Regards
January 3, 2023 at 10:52 am
benjamin.pilon
When i set the "nb of pcs" parameter to 1, everything is broken.
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
January 3, 2023 at 11:49 am
Atharv Joshi
Thanks for sharing the video. I will check and get back to you.
January 4, 2023 at 1:41 pm
Atharv Joshi
I was able to reproduce your problem at my end. When I tried changing the Count to 1, component in SpaceClaim lost the association with pattern. I am discussing it with the development and will let you know once I have any update.
This issue is resolved in Discovery and pattern doesn't destroy when count is set to 1. So maybe till I get any update. Can you please try this in Discovery and let me know how it goes?
Thanks and Regards
March 29, 2023 at 9:01 am
March 29, 2023 at 9:44 am
Atharv Joshi
Forum ModeratorHello Benjamin P. ,
Please try installing the patch from the given link January 2023 Subscription Licensing Issue - Knowledge Base - Ansys Discovery Forum and let me know if this resolves the problem.
Thanks and Regards
March 29, 2023 at 10:37 am
benjamin.pilon
SubscriberHi again ! Atharv Joshi .
Many thanks for your help, i am now able to use DISCOVERY.
I'm struggling to understand what is the difference between SpaceClaim and Discovery ! It's seems that we have more capabilites with spaceclaim (but no simulation.)
Can you tell me ?
March 30, 2023 at 5:04 am
Atharv Joshi
Forum ModeratorThanks for the update Benjamin P.
SpaceClaim is a legacy product from Ansys and provides capabilities for modeling, geometry cleanup, drawing sheet, sheet metal operations, reverse engineering etc.
Discovery on the other hand provides you most of these geometry related features with additional front up simulation helping you explore design variation, optimize and accelerate your product design cycle.
You can go through this help documentation for more information About Ansys Discovery
Regards
- The topic ‘Self destruction of pattern function’ is closed to new replies.
6425
