July 29, 2024 at 4:03 pm
Syamantak Das
SubscriberWe aim to simulate an entire system comprising various condensers and projection lenses in a non-sequential mode.
How can we view the projected image after completing the simulation? Is it necessary to place a detector on the image plane to observe the final image? What is the recommended method to verify the final output?
In our scenario, the intensity decreases from 100% to 95% over a distance of 2-3mm from the origin. How can we optimize the system to achieve uniform intensity?Please find attached images of the lens system and the optimization window for your reference.
August 6, 2024 at 7:29 am
Niki Papachristou
Forum ModeratorHi Syamantak,
Thank you for reaching out to us!
I believe adding a detector at the image is the right way to observe the image of your non-sequential system.
Regarding the optimization I would suggest to go through this article as a starting point: Using the OpticStudio Non-Sequential Optimization Wizards.
You can also find more information on our help file in the Optimize Tab (non-sequential ui mode)
Kind Regards,
Niki
- The topic ‘Selecting a Detector for the Final Image Plane and Intensity Optimization Proces’ is closed to new replies.
