February 9, 2024 at 2:22 pm
ty_jpn
SubscriberHi everyone
The following error occurs when importing a MEMS geometry in APDL and trying to mesh the surrounding space for electrostatic field analysis.
Is there a way to deal with this?The analysis method is to import mems 3d geometry, create the analysis space in blocks and subtract the MEMS geometry from the analysis space using boolean operations.
*** ERROR ***Â TIME= 22:58:38 An unexpected error ( Segmentation Violation ) has occurred... MAPDL internal data has been corrupted. MAPDL is unable to recover and will terminate. Previously saved files are unaffected. Please send the data leading to this operation to your technical support provider, as this will allow ANSYS, Inc to improve the program. /COM,ANSYS RELEASE 2023 R1 BUILD 23.1 UP20221128 22:58:57
 *** ERROR *** CP = 7.478 TIME= 23:00:11 An unexpected error ( Segmentation Violation ) has occurred... MAPDL internal data has been corrupted. MAPDL is unable to recover and will terminate. Previously saved files are unaffected. Please send the data leading to this operation to your technical support provider, as this willÂ
allow ANSYS, Inc to improve the program. -
February 12, 2024 at 3:16 pm
ashish.khemka
Forum ModeratorHi,
Please see if the following post helps: APDL: An unexpected error ( Segmentation Violation ) has occurred (ansys.com)
Thanks and Regards,
Ashish Khemka
- The topic ‘Segmentation violations during mesh generation’ is closed to new replies.
