September 19, 2022 at 7:00 am
Dubey92
SubscriberI am running Fluent 2020R2 on a Linux system. I am able to compile the UDF using the instructions given in the Fluent UDF Manual. But when I start the simulation, it throws a segmentation fault and corrupted double linked list error. I did not face this type of issue on a Windows system when running the same case and UDF. Can someone please tell what might be the issue? Any help is much appreciated. Thanks.
September 19, 2022 at 12:15 pm
DrAmine
Ansys EmployeeIs it the same case and same UDF you are trying to compile under Windows and Linux? If yes: please check with IT / System Adminstrator.Â
Please share screenshots of Fluent Console when you compile under Linux and running: perhaps there is something written which might help debugging the issue.
September 19, 2022 at 4:48 pm
Dubey92
SubscriberHi DrAmine. Yes it is the same case and UDF I am trying to compile on the Linux system. I will share the screenshot.
September 20, 2022 at 6:08 am
DrAmine
Ansys EmployeeOkay.
- The topic ‘Segmentation fault and corrupted double linked list in UDF’ is closed to new replies.
5899
1306
