January 8, 2024 at 7:25 pm
Leon15
SubscriberHello, I'm working on modelling gradually the deposition of powder by using the element birth/death technique through a transient thermal simulation. In the process, the printed parts are created separetly. However, In some cases, certain geometries lead to this error:
I am currently trying to figure out what could be causing this error, attached is an example of a geometry that is causing an error. For your information, each printed part, created as separate a volumes, is created using VMESH. The subsequent layers are then created using VGEN.
January 9, 2024 at 2:28 pm
Gary_S
Ansys EmployeeHi Leon
 Segmentation Violation is a very generic error. When does the error occur or with what command?
January 9, 2024 at 5:13 pm
January 9, 2024 at 8:18 pm
mjmiddle
Ansys EmployeeThe VMESH just meshes geometry volumes, and VGEN just copies geometry volumes. I'm not sure what you mean when you say the printed volumes are created using VMESH. As far as I know, APDL does not work with facetted geometry from mesh. Try using the VMESH after the VGEN, or detach the mesh from the geometry before using VGEN:
MODMSH, DETACH
But this will created problems later when you try to set loads, supports, connections to geometry.
January 9, 2024 at 8:20 pm
mjmiddle
Ansys EmployeeYou should provide more or your APDL code.
January 9, 2024 at 9:12 pm
Leon15
SubscriberFINISH/CLEAR ALL/FILNAME,BJ_200,0/PREP7SHPP,offET,1,SOLID278   !ELEMENT TYPE! Material properties!material properties for: POWDERMPTEMP,1,0MPDATA,DENS,1,,4830MPTEMP,,,,,,,,MPTEMP,1,25MPTEMP,2,50MPTEMP,3,75MPTEMP,4,100MPTEMP,5,125MPTEMP,6,150MPDATA,C,1,,461.8MPDATA,C,1,,469.3MPDATA,C,1,,476.1MPDATA,C,1,,482.4MPDATA,C,1,,488.1MPDATA,C,1,,493.2MPTEMP,,,,,,,,MPTEMP,1,25MPTEMP,2,50MPTEMP,3,75MPTEMP,4,100MPTEMP,5,125MPTEMP,6,150MPDATA,KXX,1,,0.17MPDATA,KXX,1,,0.18MPDATA,KXX,1,,0.19MPDATA,KXX,1,,0.21MPDATA,KXX,1,,0.22MPDATA,KXX,1,,0.22!material properties for: GLUEDMPTEMP,1,0MPDATA,DENS,2,,5228.8MPTEMP,,,,,,,,MPTEMP,1,25MPTEMP,2,50MPTEMP,3,75MPTEMP,4,100MPTEMP,5,125MPTEMP,6,150MPDATA,C,2,,2134.4MPDATA,C,2,,2141.9MPDATA,C,2,,2154.9MPDATA,C,2,,2168.7MPDATA,C,2,,2174.4MPDATA,C,2,,2179.4MPTEMP,,,,,,,,MPTEMP,1,25MPTEMP,2,50MPTEMP,3,75MPTEMP,4,100MPTEMP,5,125MPTEMP,6,150MPDATA,KXX,2,,0.21MPDATA,KXX,2,,0.22MPDATA,KXX,2,,0.23MPDATA,KXX,2,,0.23MPDATA,KXX,2,,0.23MPDATA,KXX,2,,0.23!material properties for: GREENMPTEMP,1,0MPDATA,DENS,3,,4520MPTEMP,,,,,,,,MPTEMP,1,25MPTEMP,2,50MPTEMP,3,75MPTEMP,4,100MPTEMP,5,125MPTEMP,6,150MPDATA,C,3,,463MPDATA,C,3,,472MPDATA,C,3,,480MPDATA,C,3,,487MPDATA,C,3,,494MPDATA,C,3,,500MPTEMP,,,,,,,,MPTEMP,1,25MPTEMP,2,50MPTEMP,3,75MPTEMP,4,100MPTEMP,5,125MPTEMP,6,150MPDATA,KXX,3,,1.26MPDATA,KXX,3,,1.29MPDATA,KXX,3,,1.31MPDATA,KXX,3,,1.33MPDATA,KXX,3,,1.34MPDATA,KXX,3,,1.34RECTNG,0,0.405,0,0.405 !Print bedRECTNG,0.193,0.212,0.193,0.212 !Part 1RECTNG,0.1575,0.2475,0.16257,0.17757 !Part 2RECTNG,0.1575,0.2475,0.22743,0.24243 !Part 3!!!!!!!!!!!!!!  The top face has been partitioned  !!!!!!!!!!!!!!APTN,all ! PARTITIOING THE CREATED BOXESNUMMRG,ALL, , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERSASEL,S,LOC,X,0,0.405ASEL,R,LOC,Y,0,0.405VEXT,all, , ,0,0,0.0001,,,,!!!!!!!!!!!!!!  We mesh the first layer here (Layer 0)  !!!!!!!!!!!!!!MSHAPE,0,3DMSHKEY,1ESIZE,0.01,0,VMESH,1VMESH,2VMESH,3VSEL, , , ,4VSWEEP, all!!!!!!!!!!!!!!  First layer is meshed up to here  (Layer 0)  !!!!!!!!!!!!!!ALLSEL*GET, MAXNODES1, NODE, 0, count,*DIM, TEMP_NODE1, ARRAY, MAXNODES1,40!! Layer 1VGEN,2,1, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 2VGEN,2,5, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 3VGEN,2,9, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 4VGEN,2,13, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 5VGEN,2,17, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 6VGEN,2,21, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 7VGEN,2,25, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 8VGEN,2,29, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 9VGEN,2,33, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 10VGEN,2,37, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 11VGEN,2,41, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 12VGEN,2,45, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 13VGEN,2,49, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 14VGEN,2,53, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 15VGEN,2,57, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 16VGEN,2,61, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 17VGEN,2,65, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 18VGEN,2,69, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 19VGEN,2,73, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 20VGEN,2,77, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 21VGEN,2,81, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 22VGEN,2,85, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 23VGEN,2,89, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 24VGEN,2,93, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 25VGEN,2,97, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 26VGEN,2,101, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 27VGEN,2,105, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 28VGEN,2,109, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 29VGEN,2,113, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 30VGEN,2,117, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 31VGEN,2,121, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 32VGEN,2,125, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 33VGEN,2,129, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 34VGEN,2,133, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 35VGEN,2,137, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 36VGEN,2,141, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 37VGEN,2,145, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 38VGEN,2,149, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 39VGEN,2,153, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 40VGEN,2,157, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 41VGEN,2,161, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 42VGEN,2,165, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 43VGEN,2,169, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 44VGEN,2,173, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 45VGEN,2,177, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 46VGEN,2,181, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 47VGEN,2,185, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 48VGEN,2,189, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 49VGEN,2,193, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 50VGEN,2,197, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 51VGEN,2,201, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 52VGEN,2,205, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 53VGEN,2,209, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 54VGEN,2,213, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 55VGEN,2,217, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 56VGEN,2,221, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 57VGEN,2,225, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 58VGEN,2,229, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 59VGEN,2,233, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 60VGEN,2,237, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 61VGEN,2,241, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 62VGEN,2,245, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 63VGEN,2,249, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 64VGEN,2,253, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 65VGEN,2,257, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 66VGEN,2,261, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 67VGEN,2,265, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 68VGEN,2,269, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 69VGEN,2,273, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 70VGEN,2,277, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 71VGEN,2,281, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 72VGEN,2,285, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 73VGEN,2,289, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 74VGEN,2,293, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 75VGEN,2,297, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 76VGEN,2,301, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 77VGEN,2,305, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 78VGEN,2,309, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 79VGEN,2,313, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 80VGEN,2,317, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 81VGEN,2,321, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 82VGEN,2,325, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 83VGEN,2,329, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 84VGEN,2,333, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 85VGEN,2,337, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 86VGEN,2,341, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 87VGEN,2,345, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 88VGEN,2,349, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 89VGEN,2,353, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 90VGEN,2,357, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 91VGEN,2,361, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 92VGEN,2,365, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 93VGEN,2,369, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 94VGEN,2,373, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 95VGEN,2,377, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 96VGEN,2,381, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 97VGEN,2,385, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 98VGEN,2,389, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 99VGEN,2,393, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 100VGEN,2,397, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 101VGEN,2,401, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 102VGEN,2,405, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 103VGEN,2,409, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 104VGEN,2,413, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 105VGEN,2,417, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 106VGEN,2,421, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 107VGEN,2,425, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 108VGEN,2,429, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 109VGEN,2,433, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 110VGEN,2,437, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 111VGEN,2,441, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 112VGEN,2,445, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 113VGEN,2,449, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 114VGEN,2,453, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 115VGEN,2,457, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 116VGEN,2,461, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 117VGEN,2,465, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 118VGEN,2,469, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 119VGEN,2,473, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 120VGEN,2,477, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 121VGEN,2,481, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 122VGEN,2,485, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 123VGEN,2,489, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 124VGEN,2,493, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 125VGEN,2,497, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 126VGEN,2,501, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 127VGEN,2,505, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 128VGEN,2,509, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 129VGEN,2,513, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 130VGEN,2,517, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 131VGEN,2,521, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 132VGEN,2,525, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 133VGEN,2,529, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 134VGEN,2,533, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 135VGEN,2,537, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 136VGEN,2,541, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 137VGEN,2,545, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 138VGEN,2,549, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 139VGEN,2,553, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 140VGEN,2,557, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 141VGEN,2,561, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 142VGEN,2,565, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 143VGEN,2,569, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 144VGEN,2,573, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 145VGEN,2,577, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 146VGEN,2,581, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 147VGEN,2,585, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 148VGEN,2,589, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 149VGEN,2,593, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 150VGEN,2,597, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 151VGEN,2,601, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 152VGEN,2,605, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 153VGEN,2,609, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 154VGEN,2,613, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 155VGEN,2,617, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 156VGEN,2,621, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 157VGEN,2,625, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 158VGEN,2,629, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 159VGEN,2,633, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 160VGEN,2,637, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 161VGEN,2,641, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 162VGEN,2,645, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 163VGEN,2,649, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 164VGEN,2,653, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 165VGEN,2,657, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 166VGEN,2,661, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 167VGEN,2,665, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 168VGEN,2,669, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 169VGEN,2,673, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 170VGEN,2,677, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 171VGEN,2,681, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 172VGEN,2,685, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 173VGEN,2,689, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 174VGEN,2,693, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 175VGEN,2,697, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 176VGEN,2,701, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 177VGEN,2,705, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 178VGEN,2,709, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 179VGEN,2,713, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 180VGEN,2,717, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 181VGEN,2,721, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 182VGEN,2,725, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 183VGEN,2,729, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 184VGEN,2,733, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 185VGEN,2,737, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 186VGEN,2,741, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 187VGEN,2,745, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 188VGEN,2,749, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 189VGEN,2,753, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 190VGEN,2,757, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 191VGEN,2,761, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 192VGEN,2,765, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 193VGEN,2,769, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 194VGEN,2,773, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 195VGEN,2,777, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 196VGEN,2,781, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 197VGEN,2,785, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 198VGEN,2,789, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS!! Layer 199VGEN,2,793, , , , ,0.0001,0*REPEAT,4,,1,NUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERSASEL,S,LOC,X,0,0.405ASEL,R,LOC,Y,0,0.405ASEL,R,LOC,Z,0VEXT,all, , ,0,0,-0.0009,,,,VSEL,R,LOC,Z,-0.0009,0VSWEEP, ALLALLSELNUMMRG,ALL, 1e-5 , , ,LOW ! MERGING THE COMPONENTS INTO ONENUMCMP,ALL  ! COMPRESS THE NUMBERS -
January 10, 2024 at 7:56 am
mjmiddle
Ansys EmployeeI was able to run your script to the end in 2023 R2 APDL. Maybe it's a version issue. What version are you using? Can you update? Are you uing a student version? There are some limitations there with number of elements.
January 10, 2024 at 2:20 pm
Gary_S
Ansys EmployeeIt could be a platform issue. Is this on Windows or Linux?Â
January 10, 2024 at 3:07 pm
January 11, 2024 at 1:16 am
mjmiddle
Ansys EmployeeI repeated the error in 2022 R1. All versions after that work on this model. You should update.
January 11, 2024 at 2:37 pm
Leon15
SubscriberAlright! Thank you everybody for your time and support, it is really appreciated.
- The topic ‘Segmentation Violation Error’ is closed to new replies.
5834
