Section planes using PyMAPDL
    • Antonio Zamora
      I'm trying to perform a section plane using PyMAPDL but after looking into the documentation I could not find the '/TYPE' equivalent command (https://ansyshelp.ansys.com/public/account/secured?returnurl=////Views/Secured/corp/v251/en/ans_cmd/Hlp_C_TYPE_sl.html).
      It seems that 'mapdl.type()' is the equivalent for the APDL 'TYPE' command (used to set the type element pointer).
      I wonder if there is any alternative to PyMAPDL '/TYPE' command to make section planes or If I'm missing something in the documentation.
      Thanks in advance.
      Best regards,
      Antonio.
    • Antonio Zamora
      Hi again,
      I just have found the use of 'mapdl.run()' command to run undocumented APDL commands (https://mapdl.docs.pyansys.com/version/stable/api/_autosummary/ansys.mapdl.core.Mapdl.run.html#ansys.mapdl.core.Mapdl.run).
      I mark the thread as answered and it can be closed.
      Best regards,
      Antonio.
