Section Plane showing up as “grey” in results tab.
    • bdebauch
      I'm trying to create a section plane in the middle of a cylinder. In my Static Structural tab>solutions >results> section plane shows up grey, is there is a way to enable it. I'm using ANSYS Mechanical R19.1
      Would greatly appreciate the help!
      Thanks,
      Bret
    • Aniket
      In order to that option to activate, you will need to have at least one section plane active in your model.
      You can create one using the button here:
      -Aniket
  • The topic ‘Section Plane showing up as “grey” in results tab.’ is closed to new replies.
