April 25, 2019 at 3:28 am
ejp4568
Subscriber Hello,
I would like to run scripts that generate maxwell simulations for me. There are several key features I can't manage to do from script however. First off, I would like to be able to interact with names just from the script without having to be in maxwell, and I can't seem to find an option to pull all the names of the signals in the design. Otherwise, I don't know what each specific part is called and I wont be able to interact. I also want to be able to do things like assign excitations, but I don't see how to do that other than by knowing exactly which number face it is that I am looking at. Optimally I would like to be able to do so by coordinate in space, is there a way for me to do this? I've found most of the ANSYS scripting guides pretty unhelpful, so if there is a better resource, please let me know.
June 14, 2019 at 7:38 pm
Xiaoyi Zhao
Ansys EmployeeHi,
Using "Tools - Record scripts to file" is always a good way to start. And searching the scripting manual for commands like GetObjectIDByName may help with more specific operations of what you are trying to do.Â
- The topic ‘Scripting in ANSYS maxwell’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4167
1487
1363
1194
