October 31, 2024 at 9:39 am
joe.lindley
SubscriberI'm looking to create a script to add end releases to a line body model I have imported with many verticies. The default end release is acceptable as a start point, and I will manually select those that need releases changed at a later point. I would like to have the end releases applied across the board automatically rather than add them manually later. Â
I have started by creating a named selection for the vertices:
with Transaction(True):
  # Create an empty named selection for vertices
  named_selection_vertex = model.AddNamedSelection()
  named_selection_vertex.Name = "Vertices"
  named_selection_edge = model.AddNamedSelection()
  named_selection_edge.Name = "Edges"
And follow that up with trying to gather the verticies and edges into their named selections.
And this is where I stumble as I'm not sure how to call up the vertexes or edges. For bodies etc. i have used datamodelobjectcategory , but they do not exist there. Can i use IGeoVertex in some way?Â
Thanks for your help,
Joe -
October 31, 2024 at 9:45 am
ErKo
Ansys EmployeeHi
See here how to obtain geometry:
https://discuss.ansys.com/discussion/1857/how-to-get-geometry-data-from-mechanical-model-via-scriptAny questions post in that forum as it is dedicated for that (scripting).
All the best
Erik
October 31, 2024 at 9:49 am
joe.lindley
Subscriberthats fantastic thank you - sorry for the mis located post!Â
October 31, 2024 at 10:05 am
ErKo
Ansys Employeehappy to help.
anything post there and I will help on the other side.
Erik
- The topic ‘Scripting Help – Vertices and End Releases’ is closed to new replies.
5849
