March 20, 2024 at 9:26 am
Dhiman Nag
SubscriberHi all,
I would like to add the electronic propoerties of material InGaAsP with x=0.5 and y=0.5 in Charge solver. Can someone tell me how to do that with Lumerical/Python script?
March 20, 2024 at 9:08 pm
Amrita Pati
Ansys EmployeeHi Dhiman,
Once you create the material from the database:
 You can use the following line of code to look at the list of properties that can be changed:
select("materials::InGaAsP::InGaAsP x=0.5 y=0.5");
?set;But there is a slight caveat, while setting the properties, you will have two different entities, one for the semiconductor properties (Ct) and the other for the thermal properties (Ht). The script above returns all the properties but while setting their values you need to access them individually. You can select one of them manually and then set their properties using script. But if you want to make it fully script-based then you will have to rename the two objects differently first. Then you can use the set/setnamed command again to set these properties. Here is a quick example:
#Rename the Ct and Ht
for (i=1:getnumber) {
set("name","InGaAsP x=0.5 y=0.5_"+num2str(i),i);
#Set properties of Ctsetnamed("materials::InGaAsP::InGaAsP x=0.5 y=0.5_1","work function",3);
setnamed("materials::InGaAsP::InGaAsP x=0.5 y=0.5_1","dc permittivity",3);Regards,
Amrita -
March 22, 2024 at 10:55 am
Dhiman Nag
SubscriberDear Amrita,
Thank you for the reply. It works. I am curious if the initial step i.e. 'creating material from database' can also be done through script. I can add simple material e.g. Silicon with the below scriptaddmodelmaterial;
set("name","Silicon");
addmaterialproperties("CT","Si (Silicon)");But I cannot add InGaAsP with x=0.5 and y=0.5 in the same way.
Dhiman
- The topic ‘Script to add material InGaAsP in Charge’ is closed to new replies.
5664
1890
1419
1304
