October 9, 2023 at 9:07 am
mdti
SubscriberHi,
I am using Ansys Workbench 2023 R1 to run Ansys Aqwa. I was able to run Hydrodynamic Diffraction analysis successfully for a floating platform. But while I tried to run Hydrodynamic response analysis, the following script error shows on the screen.Â
I did an online searching and tried to resolve the error by renaming the folder "v231" inside %AppData% and restarting Ansys Workbench but no success! Please help.
Kind regards,
Touhid
October 10, 2023 at 7:44 am
Rajeshwari Jadhav
Forum ModeratorHi Touhid,
Can you please rename the Ansys folder to Ansys.old (type %appdata% in start menu) and .ansys to .ansys.old (type %temp% in start menu)
October 10, 2023 at 9:08 am
mdti
SubscriberDear Rajeshwari Jadhav,
I did follow your instruction but I am sorry to say it is not working!
I've noticed the Hydrodyanmic Response anlysis in Aqwa runs up to the end and while updating the result then this error pops up. Probably, this error has something to update the result in the result tree. Could you please dig into it with your expert collegues and let me know their feed back?
kind regards,
Touhid
October 18, 2023 at 9:44 am
mdti
SubscriberI deleted all the results from hydrodynamic response and re-run the analysis and it worked.
- The topic ‘Script Error (code: 80004005) in Ansys Aqwa running using Ansys Workbench 2023R1’ is closed to new replies.
5729
