Script Error Ansys 2019R3
    • Ionutz83
      Hello.
      I have a problem in Ansys Workbench 2019R3 when I use the Export To Excel function for analisys results.
      I get the error
    • George Karnos
      @Ionutz83 Can you please post the picture of the errors you receive? I apologize, but we are not permitted to open attached file.nMany Thanks,nGeon
    • Ionutz83
      I enabled active X controls in IE, disabled third party browsers but nothing seems to help.nlast year it worked fine, but when we tried to use this function this year, this error appears and it does nothing.nThe problem is not related to one machine, I tried on 3 different laptops and the result is the same error.nThe configuration is:nThe problem is also present on a machine with Windows 7 so I don't think the OS is the problem, because it worked on both OS last year.nn
  • The topic ‘Script Error Ansys 2019R3’ is closed to new replies.
