January 4, 2025 at 5:50 pm
dimme32
SubscriberHello everyone,
I'm a student and use the student version. I recently encountered a problem, which I’ll share with you through the attached images. After importing the .step geometry, I open it in Design Modeler, create the enclosure, then perform a Boolean subtract, and set the "Preserve Tool Bodies" option to "Yes." Everything works fine up to this point.
However, when I open the mesh section in Ansys, I get an error (shown in the attachment). This issue does not occur if I set "Preserve Tool Bodies" to "No." The strange thing is that just a few hours ago, I was following the same steps without any problems. Suddenly, I started experiencing numerous errors.
I even had to uninstall and reinstall Ansys and restart the project from scratch, but every time I enter the mesh section after setting "Preserve Tool Bodies" to "Yes," this problem occurs.
What am I doing wrong? How can I fix this?
January 5, 2025 at 9:25 am
dimme32
SubscriberI have already tried uninstalling and reinstalling the software, and I also attempted renaming the Ansys license folder (V242) located in %APPDATA% by adding "_old"
January 6, 2025 at 2:18 pm
George Karnos
Ansys EmployeeCheck the system Operating system language and set to English.
Also, check that the project directory and temp directory have only ASCII characters in the names
January 6, 2025 at 3:45 pm
dimme32
SubscriberI have changed the operating system language to English (United Kingdom). I have checked and modified the temporary files directory (using the command prompt with %APPDATA%) as well as the project folder directory. Both now contain only ASCII characters, but the issue persists.The temporary directory (TEMP/TMP) has also been changed to C:\Temp to remove special characters from the file paths. However, despite following the steps you described, the issue has not been resolved.Â
January 6, 2025 at 3:49 pm
dimme32
SubscriberI don't understand how this problem came up all at once
January 10, 2025 at 4:16 pm
George Karnos
Ansys EmployeePlease see the following to see if has any relevence:
Script Error 800a000d in meshing
