Preprocessing
Preprocessing
Script Error
    • Zakarya
      errorHi,
       I am using Fluent to simulate fluid flow through a pipe, so, after finishing my geometry (a simple rectangle), i opened mesh selection in my workbench, then a script error appears (it says : Script if (report previousPane.Pane.Selected) (this error shows instantaneously more than 15windows). how can i fix it?
      Please post images into the text: staff are not permitted to open/download attachments.
    • Keyur Kanade
      Please check geometry before going to meshing. Is this fluids or structural analysis?
      Keyur
    • Zakarya
      error(this error shows instantaneously more than 15windows).
    • Keyur Kanade
      are you using any scripts? which version you are using? please check with latest available version.
      Keyur
Viewing 4 reply threads
  • The topic ‘Script Error’ is closed to new replies.
