November 3, 2019 at 3:31 pm
November 6, 2019 at 12:41 am
tsiriaks
Ansys EmployeeSee the bottom of this thread
/forum/forums/topic/another-work-bench-only-opening-a-grey-window/
Essentially, you need to register the DLL by starting a Command Prompt with "run as administrator" , then issue the following commands
regsvr32.exe ole32.dll
regsvr32.exe atl.dll
regsvr32.exe oleaut32.dll
regsvr32.exe scrrun.dll
regsvr32.exe jscript.dll
regsvr32.exe vbscript.dll
All must say successful
Then, open up regular Command Prompt , do not "run as administrator", and issue the following command
move "%appdata%ansys" "%appdata%ansys.old"
Thanks,
Win
- The topic ‘Script error’ is closed to new replies.
