TAGGED: -user-defined-results, beam188, von-mises-stress
August 5, 2024 at 9:40 am
ORO
SubscriberHello,
I am trying to get the Von Mises stress in beam connections. For this, I am following this guide :
https://ansys13.ansys.com/KnowledgeArticles/Phase-1/2052774/2052774.pdf
I have to create a UDR with the scoping method "Result file item" :
However, this option in not available in my model :
I can only choose Geometry selection, Named selection, trajectory or Surface.
Why is that ? for information I am using Ansys 17.0
Thanks !
August 6, 2024 at 2:32 pm
Gary_S
Ansys EmployeeThe example was created at 18.2.
It may be that in 17.0, the Scoping Method > Result File Item was not yet implemented.
It may have been a Beta option at that time. You can try to enable Beta options to see if that was the case.-
August 6, 2024 at 2:34 pm
ORO
SubscriberDamn ! I already have Beta option activated, so no luck for me I guess.
Thanks !
