October 19, 2020 at 8:50 pm
endless_paradox
SubscriberHello, I keep getting the following error and am unable to run the program. n nAn unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.n--- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.n n--- System.DllNotFoundException: Unable to load DLL 'SceneGraphChart.Components.dll:The specified module could not be found. (Exception from HRESULT: 0x8007007E)n  at Ans.SceneGraphChart.Engine.Ans_SceneGraph_Bootup(Object p_iConfiguration, Object p_iErrorHandler)n  at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)n  at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)n  at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)n  at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)n n nI have tried the following things:n nI have updated the graphics card and the drivers. I have a NVIDIA GeForce GTX 1050nI have verified that the graphics card used for Ansys is the NVIDIAnI have renamed the %APPDATA%\Ansys to %APPDATA%\Ansys_old and ran the cmd command to move the dirnI have rebooted my PC many occasions after doing some processn nI have tried uninstalling and reinstalling multiple times and I get the same error when I try to use Workbench 2020 R2. It did not work once. Please assist.n -
October 21, 2020 at 12:29 pm
ANSYS_MMadore
Forum ModeratorArray Can you send the results of the command:ndir /s C:\*scenegraphchart.*nnAlso, open up Dxdiag and post screenshot of System and Display tabs herennCan you confirm that your Windows is up to date and doesn't have any pending Windows Updates? Please install any pending updates.nnThanks,nMattn -
February 7, 2021 at 9:27 am
lutfenyardımedin
Subscriberdir /s C:\*scenegraphchart.*n Volume in drive C has no label.n Volume Serial Number is CCA2-A611nn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addinsnn11/10/2020 01:08 AM Â     SceneGraphChartn        0 File(s)       0 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\Configuratio11/10/2020 01:00 AM        287 SceneGraphChart.xmln        1 File(s)      287 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\bin\Win64nn11/10/2020 01:42 AM      278,000 Ans.SceneGraphChart.dlln11/10/2020 01:42 AM      51,696 Ans.SceneGraphChart.Interop.dlln11/10/2020 01:42 AM     1,834,480 SceneGraphChart.Components.dlln        3 File(s)   2,164,176 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\Language\denn11/10/2020 01:00 AM        929 Ans.SceneGraphChart.tsn        1 File(s)      929 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\Language\en-usnn11/10/2020 01:00 AM        900 Ans.SceneGraphChart.tsn        1 File(s)      900 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\Language\frnn11/10/2020 01:00 AM        955 Ans.SceneGraphChart.tsn        1 File(s)      955 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\Language\jann11/10/2020 01:00 AM        980 Ans.SceneGraphChart.tsn        1 File(s)      980 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\Language\mu-monn11/10/2020 01:00 AM        956 Ans.SceneGraphChart.tsn        1 File(s)      956 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Addins\SceneGraphChart\Language\zhnn11/10/2020 01:00 AM        922 Ans.SceneGraphChart.tsn        1 File(s)      922 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\Language\denn11/10/2020 01:00 AM        929 Ans.SceneGraphChart.tsn        1 File(s)      929 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\Language\en-usnn11/10/2020 01:00 AM        900 Ans.SceneGraphChart.tsn        1 File(s)      900 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\Language\frnn11/10/2020 01:00 AM        955 Ans.SceneGraphChart.tsn        1 File(s)      955 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\Language\jann11/10/2020 01:00 AM        980 Ans.SceneGraphChart.tsn        1 File(s)      980 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\Language\mu-monn11/10/2020 01:00 AM        956 Ans.SceneGraphChart.tsn        1 File(s)      956 bytesnn Directory of C:\Program Files\ANSYS Inc\ANSYS Student\v211\Framework\Language\zhnn11/10/2020 01:00 AM        922 Ans.SceneGraphChart.tsn        1 File(s)      922 bytesnn -
February 7, 2021 at 9:34 am
February 7, 2021 at 10:33 am
lutfenyardımedin
Subscriberomg can someone help me to solve this problem. I am really pissed off I am waiting almost 6 months to install and learn this shit.n -
February 7, 2021 at 10:35 am
lutfenyardımedin
SubscriberI can meet in discord or zoom please...n -
February 8, 2021 at 9:47 am
February 8, 2021 at 2:38 pm
ANSYS_MMadore
Forum ModeratorI can assure you that using inappropriate language is not the way to obtain support. It appears the last comment to your original posts received no response from you. Now you have decided to join on another thread to begin again.nnDid you ever try this suggestion? Do you have another machine that you can try installing this on ?nIf so, install it on there, copy the entire ANSYS Inc folder and put it on your machine, then setup all of the environment variables accordingly (compare to the other machine) and run the Products & CAD Configuration GUI to configure all products. This should be equivalent to install it locally on this machine.n
Viewing 10 reply threads
- The topic ‘SceneGraphChart Error’ is closed to new replies.
1890
1419
1304
