October 6, 2022 at 2:43 pm
Jonathan Brown
hi i am having trouble figuring out how to save a file to an stl file and not a scdoc file so i slice it using cura slicer thanks
October 7, 2022 at 1:52 am
Subashni Ravichandran
Forum ModeratorHello Jonathan BrownÂ
You can use the 'Save as' option, in Ansys SpaceClaim and set the format to .stl to save a file in STL format.Â
October 7, 2022 at 9:10 am
Jonathan Brown
Subashni when i try to save as it doesnt give me the option to save as any other file than scdocÂ
October 18, 2022 at 8:21 am
Can you please run "Product & CAD configuration 2022 R2" from Start Menu > Ansys 2022 R2, with "Run as Admin"?
Please make sure to have "Geometry interfaces" checked and make sure to allow "Automatic CAD configuration" while running it.
Let me know if that resolves the issue.
- The topic ‘scdoc file to stl file’ is closed to new replies.
1890
1419
1304
