June 25, 2025 at 9:52 pm
scabo
SubscriberHi
I have a 3d circular pipe flow and I am drawing the vectors on the 2D cross-section using vectors>tangential option. But i want to use the vector symbol size which is proportional to the in-plane velocity magnitude, ie sqrt(v2+w2) and not the total velocity magnitude. Does CFDPost automatically does that when i select the tangential option? I am seeng my vectos of shorter length at the pipe bottom and larger in the top part on the cross section. Is this scaling according to the total velocity magnitude or only the in-plane components of velocity? any help is greatly appreciated, thanks
June 30, 2025 at 8:26 am
Petros
Ansys EmployeeHi, from the documentation it is stated that when choosing tangential, the vector component tangential to the location will be plotted.
3427
1057
1051
896
887
